1992 GMC Truck Front Rotor Removal Fix
GMC
LLOYD52
i have a 1992 gmc 3/4 ton truck 6.2 diesel 120000 miles. i am having trouble getting the front disc rotor off. do i need to remove the bearing nut to pull the rotor off? it is an 8 lug wheel, just cant find what is holding the rotor on. will i need a wheel puller? thanks for your help.
May 27, 2007 at 5:58 PM
MICKEY-D
  • 304 POSTS
Yes, you have to remove the wheel bearing nut, and the brake caliper too. Take the dust cap off,cotter pin out, loosen and remove the nut and outer bearing. You should really get a repair manual for proper torque of the bearing nut.
Jan 7, 2010 at 3:04 PM
Suggested Repair
Remove the brake caliper, dust cap, cotter pin, wheel bearing nut, and outer bearing to free the front disc rotor. Use a repair manual for the correct bearing-nut torque.
Conversation Summary
The owner of a 1992 GMC 3/4-ton 6.2 diesel truck could not see what was holding the front disc rotor on and asked whether the bearing nut or a wheel puller was required. The expert said to remove the brake caliper, dust cap, cotter pin, bearing nut, and outer bearing, and to follow a repair manual for proper bearing-nut torque.
