1994 GMC Silverado Gas Smell in Cab
GMC
BUSMAN97
I have a 94 Siverado. After I finish filling up at the pump I smell gas in the cab. Just recently, however I had the same gas smell when I turned on my defroster, and also when I am idleing.
I haven't noticed a drop in my fuel consumption, and my engine is running perfectly.
Jan 24, 2006 at 4:17 PM
MVANNESSJR
  • 223 POSTS
Check around the engine for moisture... One of the fuel lines may be spraying fuel into the bay. You should be able to see it.
Jan 24, 2006 at 4:31 PM
SC1 RACING
  • 117 POSTS
you can also check your fuel fill neck it has a rubber vent hose that may be rotten or off.
Jan 25, 2006 at 2:05 AM
Suggested Repair
Inspect the engine bay for moisture or fuel spray from a leaking fuel line. Also check the fuel filler neck rubber vent hose for rot, cracks, or disconnection.
Conversation Summary
The owner of a 1994 Silverado reports a gasoline smell in the cab after filling up, when using the defroster, and while idling. Fuel consumption and engine operation appear normal. Experts suggest looking around the engine for fuel spraying from a line and checking the filler-neck rubber vent hose, which may be rotten or disconnected.
