smell of gas
GMC
BUSMAN97
I have a 94 Siverado. After I finish filling up at the pump I smell gas in the cab. Just recently, however I had the same gas smell when I turned on my defroster, and also when I am idleing.
I haven't noticed a drop in my fuel consumption, and my engine is running perfectly.
Jan 25, 2006 at 12:17 AM
MVANNESSJR
  • CAR REPAIR CONTRIBUTOR
  • 223 POSTS
Check around the engine for moisture... One of the fuel lines may be spraying fuel into the bay. You should be able to see it.
Jan 25, 2006 at 12:31 AM
SC1 RACING
  • 117 POSTS
you can also check your fuel fill neck it has a rubber vent hose that may be rotten or off.
Jan 25, 2006 at 10:05 AM
