GMC Worn Shocks
GMC
DVLDOG04
How do you tell when shocks go bad?
May 9, 2006 at 12:43 PM
BURRBRIAN
  • 158 POSTS
Genarally, if you push up and down on the car and it bounces pretty easy and takes a little bit to stop they are pretty wore out. They should go up and down a couple times then hold there position. If you get a lot of bouncy you are probably due.
May 9, 2006 at 1:42 PM
SB
  • 8 POSTS
I agree. Push down on the bumper. If it bounces more than twice your shocks are probably shot. You will also see some strange tire wear (scalloping) and your car will not handle very well.
May 9, 2006 at 1:49 PM
Suggested Repair
Push down on the bumper and release. If the vehicle bounces more than about twice or does not settle and hold position, the shocks are worn and should be replaced. Also look for scalloped tire wear and poor handling.
Conversation Summary
The owner asked how to tell when shocks go bad on a GMC. Replies recommend a bumper bounce test: worn shocks keep bouncing instead of settling after a couple of movements. Scalloped tire wear and poor handling were also noted as signs.
