1998 Chevrolet Silverado Running Lights
GMC
KELLY
Hi everyone, I have a 1998 Chevrolet Silverado that has no operational running lights. I'v checked the fuse and it's fine so I take it my next step is to trace the wiring? Any other ideas out there?
Thanks
Kelly
Feb 21, 2006 at 2:16 PM
KENVCR
  • 105 POSTS
Daytime running lights are basically your low beams on at a lower voltage at any time the vehical is running, with the emergency brake off. Having said that, do you have a burnt out light?. Turn engine on, leave in park, no emergency brake on. Check to make sure both high and low beam work. When a headlight burns out daytime running lights do not work. Also note on your dashboard. Do you have a headlight symbol? This light will always be on during daylight driving. When you switch on your headlights it will turn off. This bulb may also be burnt out.
Feb 25, 2006 at 11:21 AM
BURRBRIAN
  • 158 POSTS
Kelly, I don't know if they changed from 98 to 99 but my 99 silverado running lights only come on when you put the vehicle in gear. They don't work in park. They aren't hard to get to if you pull the 2 pins holding the headlight and move it out of the way. hope this helps, good luck
Mar 1, 2006 at 1:58 AM
KELLY
Thanks guys, I'll check out both suggestions and let you know what I find.
Mar 1, 2006 at 7:50 AM
Suggested Repair
With the engine running and the parking brake released, confirm whether the running lights operate only in gear rather than park. Also verify that both high and low beams work, since a burned-out headlight can disable the daytime running lights, and check the dashboard headlight indicator bulb. The headlight assembly can be moved aside by releasing its two retaining pins for inspection.
Conversation Summary
The owner of a 1998 Chevrolet Silverado reported that the running lights did not work even though the fuse was good, and asked whether to trace the wiring. One reply said daytime running lights use the low beams at reduced voltage with the engine running and parking brake off, and recommended checking for a burned-out headlight or dashboard indicator bulb. An expert added that a similar Silverado activates them only in gear, not park, and that the headlight can be accessed by pulling two pins. The owner planned to check both suggestions.
