2003 Chevrolet Silverado Brake Lights
MUSTANGGT
2003 Silverado, auto, and no cruise control. While the 3rd brake light works, the rear 2 do not. The same lights work when the hazard switch is activated. Cleaned contacts on brake light switch. What is next??
Oct 19, 2007 at 7:16 AM
BLACKOP555
  • 10,386 POSTS
test for voltage at the bulbs and try a new bulb
Oct 19, 2007 at 7:25 AM
MUSTANGGT
Lights were replaced and the the lights work when the emergency flashers are turned on...same bulbs
Oct 19, 2007 at 7:28 AM
BLACKOP555
  • 10,386 POSTS
test at the BOO under the hood. check if it is faulty or good
Oct 19, 2007 at 7:36 AM
MUSTANGGT
Sorry, second time we cehcked it was the bulbs....thanks for the help
Oct 20, 2007 at 10:45 AM
BLACKOP555
  • 10,386 POSTS
you are most welcome.
Oct 20, 2007 at 1:37 PM
Suggested Repair
Replace the rear brake light bulbs. The same sockets can still light with the hazard flashers even when the brake-light filaments are bad.
Conversation Summary
On a 2003 Chevrolet Silverado, the two rear brake lights did not work while the third brake light did, and the same bulbs lit with the hazard flashers. After cleaning the brake light switch contacts and checking voltage, a second bulb check showed the bulbs were bad and replacing them fixed the lights.
