2004 Chevrolet S-10 Motor Mount Replacement Fix
MOJO NASSAU
2.2 s10 truck - I need to replace the motor mounts. What is the procedure to do this please? I am handy with DYI automotive jobs but I have never attempted to do this procedure before.
FYI; I have replaced half shafts w/CV Joints, removed and reset a head, replaced radiators. I have ramps and the normal set of hand tools.
Some guidance please.
Mar 19, 2006 at 10:33 AM
  • 55,709 POSTS
Here is the instructions from the manual with diagrams (BELOW).
Remove the wheel and tire assembly. Refer to Tire and Wheel Removal and Installation (See: MaintenanceWheels and TiresService and Repair).
Remove the engine shield, if equipped. Refer to Engine Protection Shield Replacement (See: Body and FrameFrameSkid PlateService and Repair).
Remove the lower intermediate steering shaft. Refer to Lower Intermediate Steering Shaft Replacement (See: Steering and SuspensionSteeringSteering ColumnService and RepairLower Intermediate Steering Shaft Replacement).
Support the engine using a jack stand and a block of wood.
Remove the engine mount-to-frame bracket through bolt for the mount being replaced.
Loosen the right side through bolt.
Remove the heater pipe bracket bolt from the engine mount. Refer to Heater Outlet Hose Replacement (See: Cooling SystemHeater HoseService and RepairHeater Outlet Hose Replacement).
Raise the engine using the jack stand; the engine will tilt to one side.
Remove the engine mount bolts.
Remove the engine mount. You will need to articulate the mount in order to remove the mount.
Installation Procedure Note: You will need to articulate the mount in order to install the mount.
Install the engine mount.
Install the engine mount bolts.
Caution: Refer to Fastener Caution (See: Service PrecautionsVehicle Damage WarningsFastener Caution).
To aid in the installation of the bolts, start a bolt in position (1) first. Tighten the bolts to 50 Nm (37 lb ft) .
Lower the engine.
Install the engine mount-to-frame bracket through bolt and tighten to 85 Nm (63 lb ft) .
Install the engine coolant pipe bracket bolt from the engine mount. Refer to Heater Outlet Hose Replacement (See: Cooling SystemHeater HoseService and RepairHeater Outlet Hose Replacement).
Remove the jack stand.
Install the lower intermediate steering shaft.
Install the engine shield, if equipped.
Install the wheel and tire assembly.
May 18, 2017 at 4:42 AM
JBORDEN5
how do i replace my driverside motor mount on a 1998 s-10 4 cyl?
Oct 3, 2020 at 3:16 AM (Merged)
HMAC300
  • 48,601 POSTS
pretty much you will need to unbotl it fromt the frame, jack the engine up andunbolt it from the engine and reverse to install
TONYCAM
  • 8 POSTS
yea raise the engine and remove it it will be in two peices if it is broke so un bolt the engine side and the frame side and when you put the new one in you will have only one piece
2CP-ARCHIVES
  • 4,540 POSTS
How can I tell if motor mounts are broken. What are the signs.
Oct 3, 2020 at 3:17 AM (Merged)
HMAC300
  • 48,601 POSTS
have an assistant stand to the side and nothing in front of you or behind you. appy brake put in drive and brake torque truck. if engine lifts up on lh side alot the lh one is broken. do the same in reverse and rh is broken make sure your hood is up so assistant can see engine move
SHUA1180
I have a bad vibration in my truck that occurs throughout all speeds. It can be felt through the whole truck which makes it difficult to pinpoint it to the front or back. There is no significant shimmy in the steering wheel. The vibration feels consistent through the entire cab. I've already eliminated the possibility out of balance tires, bent rims, checked all u-joints,
replaced carrier bearing, and replaced trans mount. I've ran it up on stands and can't find any noticeable movement or wobble in the drive shaft, pinion flange, or the axles but can still feel the vibration.
I've just found that the motor mounts need replaced. The rubber has compressed and deteriorated and there is a lot of shaking at idle but not to the point of the engine contacting the frame. I am wondering if the two issues are connected. I only hear stories about mounts causing vibration at idle, but will it also cause it through all speeds?
I also noticed the vibration seems to have a consistent repeating pattern to it when driving and I sometimes feel the same pattern when the truck is stopped and in drive, which leads me to believe the mounts may be the cause. Its the first time I've had to deal with motor mounts, so I am not familiar with all the symptoms. The truck is an 89 s10 standard cab/long bed with a 4.3L and auto transmission. Thanks for any help or opinions.
did you remove the driveshaft to see if the joints are free?? if they are seized up, it will do this exact thing.
SHUA1180
Yeah, I pulled the driveshaft and checked everything from the trans output back.
the other thing i can think of is the flywheel. if it is cracked, it can cause the vibration in the power train.
does it vibrate when it is in park??
SHUA1180
Yes, it does vibrate in park. I am positive the mounts need replaced but I just don't know if it is possible to cause the issue or if they are two separate things. Like I said the vibration has a pattern to it that could be similar to the firing order of the engine.
  • 31,937 POSTS
I would be checking the engine mounts for softness and if they have collapsed i would replace them.
Suggested Repair
Support the engine with a jack stand and a block of wood. Remove the wheel and tire, engine shield if equipped, and lower intermediate steering shaft. Remove the mount-to-frame through bolt, loosen the opposite through bolt, and remove the heater pipe bracket bolt. Raise the engine so it tilts, remove the mount bolts, and work the mount out. Install the new mount, start the alignment bolt first, tighten the mount bolts to 50 Nm (37 lb ft), lower the engine, and tighten the through bolt to 85 Nm (63 lb ft). Reinstall the remaining parts.
Conversation Summary
The owner of a 2004 Chevrolet S-10 2.2 asked how to replace the motor mounts. An expert provided the service procedure: support and slightly raise the engine, remove the through bolt and mount bolts, work the mount out, then install it and torque the fasteners. Other replies described the same raise-and-unbolt method and a brake-torque check for a broken mount. A separate all-speed vibration complaint on an older S-10 was also discussed, with suggestions to inspect seized driveshaft joints, a cracked flywheel, and collapsed engine mounts.
