1994 Chevrolet S-10 Blazer Motor Mount Fix
SEXYHOTMOMMA35
i dont know what all i need to take off to change a motor mount on my 1994 s-10 blazer
May 28, 2006 at 10:54 AM
SDALTON19
  • 87 POSTS
FRONT
1. Support engine using lifting equipment.
2. Remove engine mount through bolt and nut.
3. Raise engine and remove mount to engine attaching bolts, Fig. 1 .
4. Remove engine mount.
5. Reverse procedure to install
REAR
1. Raise and support vehicle.
2. Support rear of engine using equipment.
3. Remove mount to crossmember attaching nuts and washers.
4. Remove mount to transmission attaching bolts, then the mount.
5. Reverse procedure to install. Tighten bolts to specifications shown in Fig. 2 .
this is procedure for non 4 wheel drive
May 29, 2006 at 6:21 AM
Suggested Repair
For a non-4WD 1994 S-10 Blazer, support the engine with lifting equipment. For a front mount, remove the through bolt and nut, raise the engine, remove the mount-to-engine bolts, and replace the mount. For a rear mount, raise and support the vehicle, support the rear of the engine, remove the mount-to-crossmember nuts and washers and the mount-to-transmission bolts, then replace the mount. Reinstall in reverse and tighten to specification.
Conversation Summary
The owner asked what must be removed to change a motor mount on a 1994 S-10 Blazer. The expert gave front and rear replacement steps for a non-4WD vehicle: support the engine, unbolt the mount from the engine or transmission and crossmember, remove the mount, then reverse the procedure and torque the fasteners to specification.
