1998 Chevy S-10 2WD, STD Transmission, 96000 miles. I had been having problems with my AC. When running the AC and after having pressing the clutch the RPM's would jump to 3-4000. When attempting to drive after that point the truck would stall. I remedied this by simply not using the AC and leaving the dial on heat. But now I am experiencing slight raises in idling when the clutch is pressed. It will raise to just over 1000 and remain that way for a few seconds and then return to normal. I have just recently had the Service Engine light come on and I have a TPS reading. 2 questions: 1) what is wrong with the AC and 2) could this new reading stem from that problem?
Jul 6, 2006 at 1:22 PM
