1997 Oldsmobile Aurora Rear Brake Pads
1919 GMC
CAMER
I have a 1997 olsmobile aurora with 140000 miles,I need to change the rear brake pads and I'm not sure how to get the cylinder off the rotor,,, could you please help me out with correct information on how to change the pads?? Thank you.
May 24, 2006 at 12:15 PM
LSUSSEL
  • 252 POSTS
Do you see two bolts on the backside of the cylinder?
May 24, 2006 at 2:39 PM
CAMER
actually theres only 1 bolt on the bottom and a pin on the the upper part. Does the pin come out or is it swing mechinism??
May 24, 2006 at 2:42 PM
LSUSSEL
  • 252 POSTS
Well first of all..
If the car has drum brakes take the tire off and on the back of the hub at the bottom there is a small slit (it may have a rubber bootin it) take the boot out. inside ther is a small gear with teeth on it take a flat head screw driver and put it on the teeth and turn the gear up or down to loosen it till the drum will come off.
There is a special tool needed to back in the self-adjuster nut in the center of the wheel hub assembly. This nut has to be backed in so that you can slide open the caliper sufficiently to be able to remove the old brake pads and install new ones. The nut is embossed with a shape like an hour glass (as opposed to, say, a Phillips or slot shape). The tool will snap into a 3/8" socket driver and with this, will then fit into the grooves to permit you to turn and back in the nut. In Canada, I found a multi-tool that did the job at PartSource. It was under $10. Ask at any reputable auto parts supplier - they should have it.
May 25, 2006 at 12:03 AM
Suggested Repair
Use a special tool that fits the hourglass-shaped self-adjuster nut in the center of the rear hub. Back the nut in with a 3/8-inch driver so the caliper can open enough to remove the old pads and install new ones. Auto parts stores commonly sell this inexpensive tool.
Conversation Summary
The owner of a 1997 Oldsmobile Aurora asked how to remove the rear caliper to replace the brake pads, noting one lower bolt and an upper pin. The expert first described loosening a drum-brake adjuster, then explained that a special tool is needed to retract the hourglass-shaped self-adjuster nut so the caliper can open for pad replacement.
