1995 Oldsmobile Aurora Oil Level Fault
1995 GMC
CRIDE187
I have a 1995 Olds Aurora and i just got my oil changed last week and now my computer says oil level sys fault. I dont know what it means, i called the dealer and he said it might be low on oil but it was just chaged and i checked it and it is full, so i dunno what the problem is or what that means. I also shut off the car and restarted it and pressed the RCL buttom to see any problems and it said monitored systems ok, so i drove it for 10 minutes and than the oil level sys fault came up again, can u help me out?
Feb 27, 2006 at 10:18 AM
  • 55,694 POSTS
Replace your oil level sender, It has malfunctioned
Feb 27, 2006 at 10:40 AM
CRIDE187
1995 olds aurora, 110,000miles...... how much does the oil level sender cost? and is it a complicated repair?
Feb 27, 2006 at 11:17 AM
Suggested Repair
Replace the oil level sender, which the expert said has malfunctioned.
Conversation Summary
The owner of a 1995 Oldsmobile Aurora reported an oil level system fault after a recent oil change. The oil was full, and a system check briefly showed monitored systems OK before the fault returned. An expert advised replacing the malfunctioning oil level sender. The owner then asked about cost and repair difficulty, which was not answered.
