Pontiac Aztec Power Cuts Out
GMC
DNORDWICK
While I was driving today my car power turned off and then turned right back on. It did this twice. Is this a problem with my alternator? [color=darkblue:14425a92ff][/color:14425a92ff]
Feb 8, 2006 at 12:02 AM
MVANNESSJR
  • 223 POSTS
Could be, but first check the battery cables for corrosion. Could be as simple as a loose connection.
Feb 8, 2006 at 12:32 AM
DNORDWICK
I checked the battery connection is good. I did have a battery that leaked a few months ago there is a little corrosion on cables. When the car shut down I didn't have to start it up again or anything. I'm not even sure if the car shut off....I just know the interior lights and radio went off then back on. Could it be as simple as a fuse?
Feb 8, 2006 at 12:50 AM
MVANNESSJR
  • 223 POSTS
It's probably not a fuse because a fuse can't fix itself. Once they are blown, they are blown. It is probably something simple though.
Feb 8, 2006 at 12:07 PM
DNORDWICK
[color=blue:7ea1af3508][/color:7ea1af3508][size=18:7ea1af3508][/size:7ea1af3508]After work the radio and control panel were switching on and off every couple of seconds. It also made a clicking noise coming from behind the radio. I took the vehicle to Auto Zone and had everything checked. Everything was fine. A guy there works at a shop and he looked at it and said he's never seen a car do that before. He said it could be in my tbs? I'm not sure what that is. It didn't do that at all this morning. It is running fine for now.
Feb 9, 2006 at 12:35 AM
MVANNESSJR
  • 223 POSTS
I'm not sure what he was referring to either. It is strange for sure, but does sound like some kind of short in the electrical system. What makes it worse is it happens at random. :|
Feb 9, 2006 at 1:57 AM
Suggested Repair
Clean the remaining corrosion from the battery cables and confirm the connections are tight. A fuse is unlikely because the power returns by itself. Have an intermittent electrical short checked, especially around the radio and control panel where clicking and repeated on-off cycling were noted.
Conversation Summary
The owner of a Pontiac Aztec reported that power, the interior lights, and the radio briefly cut out while driving and then returned without a restart. The radio and control panel later switched on and off repeatedly, with a clicking noise behind the radio. The battery connections were tight, but some corrosion remained from an earlier battery leak, and a parts-store test found no charging problem. The expert recommended checking the battery cables, said a blown fuse would not reset itself, and suspected an intermittent electrical short.
