Oldsmobile Alero Temp Gauge Fluctuates
GMC
JACY332
My temperature gauge has been acting up. It stays above the middle and goes up and down while I am driving. It will go all the way to the bottom of the red and then just drop right back to the middle after a few seconds and then do it all over again. I took it to 2 different garages. The first told me there was an air pocket in the thermostat that they cleaned out. I don't even think they looked at it though. I took it to another one who changed my thermostat and did something to the gauge and it is still doing it. They said it could be my cluster going bad. Any advice on what it could be because it's driving me nuts!
Jan 24, 2006 at 11:05 PM
SC1 RACING
  • 117 POSTS
the way you describe it it is what would be suspected of a bad thermostat. try taking the thermostat out run it up to temp and see if it still flucuates. if it does it could be a faulty temp sensor.
Jan 25, 2006 at 2:11 AM
Suggested Repair
Remove the thermostat and run the engine up to temperature to check whether the gauge still fluctuates. If it does, suspect a faulty temperature sensor.
Conversation Summary
The owner of an Oldsmobile Alero reports the temperature gauge rising toward the red and then dropping back to the middle repeatedly while driving. Two shops addressed a possible air pocket and replaced the thermostat, and one suggested a failing instrument cluster, but the problem continues. An expert suspects a thermostat issue and recommends testing by removing the thermostat and running the engine to temperature; if the gauge still fluctuates, a faulty temperature sensor is a possible cause.
