2000 Malibu Lighter Fuse Blows Instantly
dont use a higher rated fuse unless you want to burn up your vehicle. Simple things to check, are inside the cig lighter for metal object. Otherwise find what else is on the circuit and check for wires shorted to ground
Suggested Repair
Disconnect all accessories from the cigarette lighter and aux charger, then install only the correct fuse rating. Inspect the lighter socket for a metal object or other short, and check the rest of that circuit for wires shorted to ground. Do not use a higher-amp fuse.
Conversation Summary
A 2000 Malibu blows the mini blade fuse for the lighter and aux charger as soon as a new fuse is installed. One reply suggested disconnecting the battery and, if needed, trying a higher-amp fuse. Another reply warned that a higher-rated fuse could cause a fire and advised checking the lighter for a metal object and looking for wires shorted to ground. The expert asked about recent modifications or anything plugged into the lighter, and recommended disconnecting all accessories, using the proper fuse rating, and inspecting the lighter for a short.
