2000 Chevy Malibu Jerks Uphill
DAREK
  • 5 POSTS
My 2000 Chevy Malibu jerks, bucks slightly on the steady uphill run,
goes away if I accelerate hard, what could be a problem?
Sep 4, 2007 at 7:14 AM
CLY
  • 308 POSTS
I would start by looking at the spark plugs and the wires. Make sure and check the wires at the coil towers aswell...
Cly
Sep 4, 2007 at 9:30 AM
DAREK
  • 5 POSTS
I did that. No change.
Someone mention to me MAF sensor, could that be it?
Sep 5, 2007 at 2:28 AM
CLY
  • 308 POSTS
I dought that it wil be a mass air flow problem. you can try and clean it and see if it helps. When the car is doing it place your left foot on the brake pedal slightly so that the torque converter disengauges and see if it stll does it. I have seen torque converter solenoids cause a surging condition.
What motor is in it?
Cly
Sep 5, 2007 at 11:02 PM
DAREK
  • 5 POSTS
It has 3.1 V6
Ok will try to clean it tonight
So you are saying I should press brake slightly while driving when it happens?
Sep 6, 2007 at 5:25 AM
CLY
  • 308 POSTS
Yes.... Pusing the brake slightly will disengauge the torque converter.
Cly
Sep 6, 2007 at 2:15 PM
DAREK
  • 5 POSTS
Looks like the cleaning of the MAF filter did the trick!!!
It works smooth for now.
Thx
Darek
Sep 10, 2007 at 4:00 AM
Suggested Repair
Check spark plugs and plug wires, including the coil towers. If that does not help, clean the MAF sensor. A slight brake application while the jerking occurs can also help check whether a torque converter solenoid is causing the surge.
Conversation Summary
A 2000 Chevrolet Malibu with a 3.1 V6 jerked and bucked slightly during a steady uphill run, but the symptom went away under hard acceleration. Spark plugs and wires, including the coil towers, were checked with no change. The expert doubted a MAF problem but suggested cleaning it and also described a light brake-pedal test to see whether a torque converter solenoid was causing the surge. Cleaning the MAF sensor resolved the jerking.
