car makes a ticking noise sometimes
MICROMAN
Hi all I drive a 2001 Malibu 3.1 v6 with 153000 km,sometimes when I start the car the motor makes a ticking sound wich is quite loud ,the noise goes and comes and sometimes stays away for several days what is it?
Aug 10, 2007 at 2:14 AM
  • 75,988 POSTS
[quote:7eb14db6e6="microman"]Hi all I drive a 2001 Malibu 3.1 v6 with 153000 km,sometimes when I start the car the motor makes a ticking sound wich is quite loud ,the noise goes and comes and sometimes stays away for several days what is it?[/quote:7eb14db6e6]
That ticking noise is it coming from the top of the engine-you need to be specific
Aug 10, 2007 at 2:25 AM
  • 75,988 POSTS
Subject: noisy malibu
Hi Rasmataz ,the noise seems to be coming from the top back left corner of the engine when you are standing in front of the car
thank you for showing intrest.
Try checking for a loose or disconnected sparkplug wire and again you'll know bcuz it will misfire.
Also could be leakdown problem with the lifters on that side or needs adjustment.
Hope this helps
Aug 10, 2007 at 3:00 AM
