Ticking sound
2005 CHEVROLET MALIBU
213,780 MILES • 3.5L • 6 CYL • FWD • AUTOMATIC
MSJAMES13
When i accelerate i hear it but it is off and on. Also, when i sit still i can hear it. i have an oil leak.
Jun 20, 2017 at 8:28 AM
HMAC300
  • 48,601 POSTS
first fill with oil and see if it goes a way. if not have a mechanic check for a bad lifter/rocker arm. It may be leaking oil out too much and making the noise as well.
Jun 20, 2017 at 8:34 AM
MSJAMES13
Thank you. i am in process of a oil change at this moment. also, is it okay to use high mileage oil treatment?
Jun 20, 2017 at 8:35 AM
MSJAMES13
HMAC300 do you think it is okay to use oil treatment?
Jun 20, 2017 at 8:58 AM
HMAC300
  • 48,601 POSTS
you should use what is required, but I imagine you can use high mileage with no problems as long as it is not above 10w30.
Jun 20, 2017 at 9:49 AM
