1999 GMC Suburban Door Lock Relay
GMC
SW10475
My power door locks on my 1999 Surburban usuallly work the first or second time by using the door controls or the remote. After that they will not lock or unlock. After sitting for a few hours they will work ok but only once then quit again. The rear doors seem to work ok, the problem is with the other 4 doors. What could be causing this?
May 1, 2006 at 3:21 AM
LOSONE
  • 1,616 POSTS
You may have a lazy door lock relay. It is located high above your emergency brake assembly. It is black, flat and about 3" long. Good luck
May 1, 2006 at 7:33 AM
Suggested Repair
Check or replace the door lock relay located high above the emergency brake assembly. It is black, flat, and about 3 inches long. A lazy relay can let the locks work once or twice, then fail until they rest.
Conversation Summary
The owner of a 1999 Suburban reports that the power door locks usually work once or twice from the door switches or remote, then will not lock or unlock until the vehicle sits for a few hours. The rear doors work; the other four doors do not. The expert suggests a lazy door lock relay above the emergency brake.
