1984 GMC Suburban Overheating
1984 GMC
BHELMS613
i have a 1984 GMC surburban and it keeps overheating. I have to put water in it every 2-3 days. it does not seem to be leaking anywhere and the water pump doesn't seem to be leaking either. i had the Trany replaced 3 months ago. any suggestiond would be greatly appreciated!!
Nov 8, 2006 at 10:52 AM
BACKYARDMECHANIC
  • 337 POSTS
Dear Bhelm,
Sounds like you could have a blown head gasket. The coolant has to be going somewhere and if you have no leaks it could be going out the tailpipe. Hear are some things you can check. 1) check the coolant to see if there is any engine oil present. 2) check the dip stick to see what color the oil is. If coolant is getting into the oil it will have a milky color look to it. 3) You can do a compression check to see if the head gasket is blown. If it is you will have low compression in probably two adjacent cylinders. 4) Pressure test the coolant system to rule out any leaks not visible under regular conditions.
Good luck Backyardmechanic :)
Nov 9, 2006 at 5:30 AM
Suggested Repair
Suspect a blown head gasket if coolant is disappearing without an external leak. Check the coolant for oil and the oil for a milky appearance, perform a compression test for low readings in adjacent cylinders, and pressure-test the cooling system for hidden leaks.
Conversation Summary
The owner of a 1984 GMC Suburban reports overheating and needing to add water every two to three days, with no visible coolant leak and no apparent water-pump leak. The transmission was replaced three months earlier. The expert says the coolant may be exiting through the exhaust and recommends checking for oil in the coolant, milky oil, low compression in adjacent cylinders, and pressure-testing the cooling system.
