1999 Chevrolet Blazer Water Leak
GMC
VULCANWAYNE
I have a 1999 Chevrolet 4 DR Blazer 2WD that when sitting still does not leak during rain events. When I drive it during heavy rain events it takes on water in the passenger rear floor area. I have replaced door weatherstripping on both front and rear doors as well as checked to ensure drain in bottom of door panel is not obstructed. Sitting in the vehicle facing the passenger rear door the water appears to be coming in at or near right rear area of the floor near the wheel well and at the bottom left near the middle door post. It seams to be getting in between the floor panels and blowing back. Have looked underneath and attempted to seal all open seams with frame sealer and undercoating. Any ideas?
Vulcanwayne
May 9, 2006 at 8:06 AM
LOSONE
  • 1,616 POSTS
Yes, i have and have had limited success. The water is probably coming in through the fender well. Check it carefully with the wheel off. A good shot of spray undercoating wouldn't hurt.
May 9, 2006 at 10:51 AM
Suggested Repair
Remove the rear wheel and carefully inspect the fender well for the water entry point. Seal the area with spray undercoating.
Conversation Summary
A 1999 Chevrolet Blazer takes on water in the rear passenger floor only while driving in heavy rain, not when parked. Door weatherstripping, door drains, and underside seams were already checked or sealed. The expert said the water is likely entering through the fender well and recommended inspecting it with the wheel removed and applying spray undercoating.
