1990 Chevrolet Pickup Ignition Timing
GMC
SWEET TART
  • 15 POSTS
I have a 1990 Chevrolet Pickup with 190,000 miles, I run a 350 strocked out to 383 I run a Crowler 300 cam hydrolic lift should my time be set to 4 degree high during hot weather? :roll:
Apr 24, 2006 at 11:29 PM
LOSONE
  • 1,616 POSTS
If you still have computer control 4 sounds about right. I have run it as high as 10 as long as the engine will start with out a bog. Good luck
Apr 25, 2006 at 4:58 AM
SWEET TART
  • 15 POSTS
Thank you....
Apr 25, 2006 at 5:09 AM
Suggested Repair
If the engine still has computer control, about 4 degrees of ignition advance is reasonable in hot weather. Advance can be as high as about 10 degrees if the engine starts without bogging.
Conversation Summary
The owner of a 1990 Chevrolet pickup with a stroked 350/383 and a Crower hydraulic cam asked whether ignition timing should be set 4 degrees advanced in hot weather. The expert said 4 degrees is about right with computer control, and that up to 10 degrees is possible if the engine starts without bogging.
