1974 Chevy 3/4 Pickup Rotor Not Turning
GMC
EWMBN65
74 chevy 3/4 PU 350 eng. 150,000+ miles
The truck lost power and stalled thought it was out of fuel but it wasn't. Just replaced distributor cap and rotor cap,pulled distributor cap to check points and discovered rotor cap wasn;t turning when I had someone crank it while I watched. Got any Ideas on what I should do next?
Mar 28, 2006 at 2:22 PM
BURRBRIAN
  • 158 POSTS
:cry: Boy, do I have some bad news for you. It has been my experience when this happens that you have a timing chain gone bad, probably the gears ,too. The good part is this isn't too expensive,
something like 25-30 bucks for chain and gears, then the timing cover and oil pan gaskets are another 20 bucks or so. The bad part is changing them. Not too bad if you have another set of hands to help.Just make sure you get your marks on the gears lined up right and you should be back on the road before long. :D
Mar 28, 2006 at 2:33 PM
Suggested Repair
Replace the timing chain and gears, along with the timing cover and oil pan gaskets. Align the timing marks on the gears correctly during installation.
Conversation Summary
A 1974 Chevy 3/4-ton pickup with a 350 engine lost power and stalled. After the distributor cap and rotor were replaced, the rotor did not turn while the engine was cranked. The expert said this usually indicates a failed timing chain and likely worn gears, and recommended replacing the chain, gears, timing cover gasket, and oil pan gasket, then aligning the gear timing marks.
