1993 GMC Idle Surges Then Settles
GMC
WATERBOY1971SS
i have a 1993 v6 4.3 gmc 1/2 ,when the truck is first started the engine idles up real high then real low almost dies, about few mins later the engine will rev real high and then it runs fine until u kill it , then it satarts all over again
Sep 28, 2006 at 10:44 AM
MICKEY-D
  • 304 POSTS
It acts like the EGR valve is opening at the wrong time. try pulling off the vacuum line or lines to it and plugging them. If it idles normally, the sender for the valve is bad. Trace the lines back, it's a water temp activated sensor.
Jan 7, 2010 at 3:53 PM
Suggested Repair
Disconnect and plug the vacuum line or lines to the EGR valve. If idle then becomes normal, the water-temperature-activated EGR vacuum sender is bad; trace the lines back and replace that sensor.
Conversation Summary
A 1993 GMC half-ton with a 4.3 V6 idles very high, then very low and nearly dies after a cold start. After a few minutes it revs high once and then runs normally until shut off, when the cycle repeats. The expert said the EGR valve may be opening at the wrong time and recommended plugging its vacuum lines as a test. Normal idle after plugging points to a failed water-temperature-activated EGR vacuum sender.
