2003 Chevy Trailblazer Headlight Bulb Out
GMC
BIGDOGS63074
I have a chevy trailblazer 03 with 82566 miles and i have a headlight that is out. I am unable to figure out on how to replace the burnt out bulb. if you have a diagram. or whatever id appreciate it.
May 1, 2006 at 9:03 AM
BURRBRIAN
  • 158 POSTS
Well, if the setup is close from your's to mine, 99 Silverado,
you can pull 2 pins that hold light housing in, taking it loose and then the bulb socket shoud be a twist out type. Be careful about getting the new bulb dirty or a lot of skin oil on it as this causes them to burn out fairly quick for some reason. Hope this helps you out. :roll:
May 1, 2006 at 12:16 PM
Suggested Repair
If the headlight assembly is similar to a 1999 Silverado, release the two pins holding the housing, then twist the bulb socket out. Avoid touching the new bulb with bare skin, since skin oil can cause early failure.
Conversation Summary
The owner of a 2003 Chevy Trailblazer with 82,566 miles has a burned-out headlight and cannot determine how to replace the bulb. An expert suggested releasing two housing pins and twisting out the bulb socket, based on a similar Silverado setup, and warned against getting skin oil on the new bulb.
