2000 Chevrolet Trailblazer Fast Blinker
BOUGS021
Has 75,000 miles, the turn signal flashes much quicker now to one side compared to other side. The bulbs all appear to be working. Was told that the flasher unit may be going out and this is the warning. Don't know if its true, bought a replacement, can't locate the unit. The replacement has four prongs, three in a row and one below. Please help.
Feb 15, 2007 at 6:19 AM
CHEVY22
  • 1,375 POSTS
FLASHER LOCATION IS UNDER THE RIGHT SIDE OF THE GLOVE BOX BELOW THE GLOVE BOX, BUT BEFORE YOU REPLACE IT HAVE SOMEONE ELSE HELP CHECK YOUR LIGHTS , YOU MAY HAVE A FILIMENT OUT
JIM
Feb 15, 2007 at 6:30 AM
Suggested Repair
Have a helper check all turn-signal bulbs and filaments before replacing the flasher, since a burned filament can cause fast flashing. If the bulbs are good, the flasher is under the right side of the glove box.
Conversation Summary
The owner of a 2000 Chevrolet Trailblazer with 75,000 miles reports that the turn signal flashes much faster on one side than the other, although the bulbs appear to work. They were told the flasher may be failing and bought a four-prong replacement but could not find the unit. The expert says the flasher is under the right side of the glove box and recommends checking the lights with a helper first because a filament may be out.
