If everything is hooked up the only thing it could be is a overflow for the system. Which in no way could drain the entire system. If you had a bad rad cap it would let some pass but not just sitting after engine is cool.
Try to find a repair manuel and locate all of the coolant hoses. Make sure everything is connected.
Also look at any coolant line that could be leaking and running down to that pipe.
Wednesday, January 25th, 2006 AT 12:30 PM
