Confused and frustrated
GMC
JADEWOLF32
  • 7 POSTS
1998 Chevy Blazer ZR2 75,000 miles. OK I had some issues and codes that came up and fixed those issues. So far replaced the fuel pump, and EGR vavle. I have not had my SES light come on since, she is running a lot better, I also ran a can of sea form through to clean things up. Since then my heater core went out and cannt afford to fix it so I looped the 2 hoses together. I still have 2 things that I do not know the cause. Like I said she is running better but at times I can still feel her kinds struggle and surge, like when the EGR vavle was malfuncting but not nearly as bad, but enough to notice, I can kinda smell hot exhust? And another thing she is a 5 speed and sometimes she will not start, no noise at al,l I have to push in the clucth pedal in at least twice and kinda hard and then she will turn over. IDEAS before I shoot her?
Mar 24, 2006 at 5:30 AM
JAR671
The hot exhaust smell and poor running could be related to the catalitic convertor. If your cc gets too hot it can melt the ceramic beads into a mass, clogging up the exhaust flow to a certain degree. This causes back pressure into the cylinders and may also be harder to start. Just a thought and worth checking out. :D
Mar 24, 2006 at 9:18 AM
