1988 Chevrolet Monte Carlo Noisy Lifters Fix
GMC
CHINSY2000
  • 6 POSTS
I bought a 88 monte carlo ss that has a 1967 327 engine the owner said the lifters are getting noisy how hard are they to change and what would the cost be for new ones and what would be a good kind to install. Thanks
Apr 13, 2006 at 2:53 AM
BURRBRIAN
  • 158 POSTS
DON'T SHOOT THE MESSENGER!! I have always been taught that you DO NOT put new lifters with an old cam-new cam with old lifters. If you change out one you need to change them both. They are "wear-mated" to each other and will not last very long if you try to mix them. You can get cam-lifter sets for not much more than a cam runs. I just got a set from Summitt that run me 92.40 with install gasket set and shipping- handling. Took 3 days to get.Go to summittracing.com and look at cam kits for sb chevy, think you can find something that will work for you. :!:
Oh yeah, about installing, you have to pull dist. intake manifold, valve covers, for lifters and the oil pan,timing cover, water pump and stuff for the cam.
you may have to find someone who knows how to set lifters, adjust timing and so forth for this.
Apr 13, 2006 at 8:00 AM
Suggested Repair
Replace the camshaft and lifters together as a matched set rather than installing new lifters on the old cam. A small-block Chevy cam-and-lifter kit with gaskets is a practical option. The job requires removing the distributor, intake manifold, and valve covers for the lifters, plus the oil pan, timing cover, and water pump for the cam, and the lifters and timing should be set by someone experienced.
Conversation Summary
The owner of a 1988 Monte Carlo SS with a 1967 327 asked how hard noisy lifters are to change, what new ones cost, and which type to install. The expert advised against mixing new lifters with an old cam because the parts are wear-mated and will not last. They recommended a cam-and-lifter kit, cited a Summit kit around $92.40 with gaskets and shipping, and outlined the major disassembly and adjustment work involved.
