I have a 6 cylinder engine and there are approximately 111,000 miles on the car.
1998 Chevrolet Monte Carlo No Start
CHEVROLET
My car will not start. However, the radio and dome lights are still working. They work until the key is turned trying to start the car, then they go out. I own a 1998 Chevy Monte Carlo Z34.
Jan 26, 2007 at 3:11 AM
The lights go out or dim when you attempt to start the car because the starter is drawing alot of current. They are also working untill you turn the key because they don't draw as much current as the starter. This could be due to a defective starter, weak battery or bad connection. Start with the easy stuff first. Check all battery connections and make sure they are tight and clean. Next charge battery fully before attempt to start the car while observing the volt meter. If the car is not equipt with one then hook one up to the battery. Voltage should not go below 9 volts while cranking the motor. If it does replace battery. And finally if none of the above has corrected the problem the starter needs to be replaced. Good luck
Jan 26, 2007 at 4:25 AM
no, big mistake, before dealing with the starter take a few seconds and with a volt meter measure the volts of the ignition coil, only if when you turn the key and nothing happens ( no noise)
Jan 26, 2007 at 11:32 AM
I'am confussed! What does the ignition system have to do with the starter not cranking the motor???
Jan 27, 2007 at 2:30 AM
Suggested Repair
Check and clean the battery connections, fully charge the battery, and confirm voltage stays at or above 9 volts while cranking. Replace the battery if voltage drops below 9 volts. If the connections and battery test good, replace the starter.
Conversation Summary
The owner of a 1998 Chevrolet Monte Carlo says the car will not start. The radio and dome lights work until the key is turned to start, then they go out. One expert says the starter is drawing heavy current and recommends checking battery connections, charging the battery, verifying cranking voltage stays above 9 volts, and replacing the starter if those checks pass. A second expert suggests measuring ignition coil voltage if there is no cranking noise, which the first expert questions.
