2002 Chevrolet Monte Carlo No Start
JAMESRJARRELL
my son has a chevrolet, 2002 monte carlo with 70,000 miles. The car won't start unless jumped. The battery is new and we replaced a fuse also. Once started the car will run and does not die until turned off.
Dec 23, 2006 at 1:21 AM
SERVICE WRITER
  • 9,123 POSTS
I wouldn't rule out the battery even if it is new. I have had bad ones from the get go, rare, butdon't assume, be sure the connections are tight at the battery.and the cabes are good right to the ground and starter as well as tight at these points. By jumping you may be providing a good ground that the car battery is not getting.
Dec 23, 2006 at 1:29 PM
Suggested Repair
Do not assume a new battery is good. Verify the battery and make sure cables and connections are tight and sound at the battery, ground, and starter, since a jump may be supplying a missing ground.
Conversation Summary
The owner reports a 2002 Chevrolet Monte Carlo with 70,000 miles will not start unless jumped. The battery is new and a fuse was replaced; once started, the car runs until shut off. The expert advises testing the battery anyway and checking cable condition and tightness at the battery, ground, and starter, because jumping may be providing a ground the car lacks.
