2001 Chevrolet Monte Carlo No Start
MERTLE32
I own a 2001 Monte Carlo Ls. with 94,000 miles. Randomly my car will not start. The security light flashes and in 5 to 20 minutes my car will finally start up fine. It is becoming more frequent and is annyoing when I need to get somewhere. I do not believe it is my starter, but am not sure on what it could be. Any suggestions would be helpful.
Aug 10, 2007 at 2:42 PM
CLY
  • 308 POSTS
It sounds like the car is going into tamper mode. I would like for you to have the car scaned for codes. With your probem being intermittent I would think that maybe you have a loose connection at the Body Control Module or something like that. I would be interested to see what if any codes can be pulled from the PCM and BCM..That would also give us a starting point....
Cly
Aug 10, 2007 at 9:23 PM
Suggested Repair
Scan the PCM and BCM for codes and check for a loose connection at the body control module, which can put the car into security tamper mode and cause an intermittent no-start.
Conversation Summary
The owner of a 2001 Chevrolet Monte Carlo with 94,000 miles reports that the car randomly will not start while the security light flashes, then starts normally after 5 to 20 minutes. The problem is becoming more frequent, and the owner does not believe the starter is at fault. The expert says this sounds like tamper mode and recommends scanning the PCM and BCM for codes and checking for a loose body control module connection.
