1995 Oldsmobile Delta 88 Won't Start
GMC
JACKLBRAN
My 1995 oldsmobile delta 88 royale ran out of gas as soon as I started it up. Do you think that by running out of gas that when I put gas into it I stirred up the sedimit in the bottom of the tank ,if there was any, and plugged up the fuel filter? Or is something else wrong? Thank You, Jack L. Branson.
Mar 29, 2006 at 7:49 AM
LOSONE
  • 1,616 POSTS
9 chances out of 10 you ruined the fuel pump. It is a bear to change as you have to drop the tank. I expect about $300 bucks Good Luck!
Mar 29, 2006 at 9:16 AM
Suggested Repair
Replace the fuel pump. Running out of gas likely ruined it. Access requires dropping the fuel tank; expect about $300.
Conversation Summary
The owner of a 1995 Oldsmobile Delta 88 Royale said the car ran out of gas as soon as it was started and asked whether adding fuel stirred up tank sediment and clogged the fuel filter, or whether something else was wrong. The expert said the fuel pump was very likely ruined, that replacement requires dropping the tank, and estimated about $300.
