1992 Dodge Spirit Alarm Install
GMC
PALMIROS
  • 7 POSTS
Hi there, I have a 1992 Dodge Spirit, and I was thinking of adding an alarm system to it, now the only thing is that it doesn't have Power ANYTHING.
So my question is, if i add an alarm system (like this one -> http://cgi.ebay.ca/CAR-ALARM-SYSTEM-DODGE-NEON-INTREPID-CARAVAN-RAM-SPIRIT_W0QQitemZ8055266106QQcategoryZ33721QQssPageNameZWDVWQQrdZ1QQcmdZViewItem ), would the alarm work, considering there are no power locks (for example?)
Any suggestions are welcome.
Apr 14, 2006 at 8:31 AM
LOSONE
  • 1,616 POSTS
Yes, it will work with only the motion detector but you will have problems with unlocking the doors and not cause the motion detector to trigger an alarm. Good luck
Apr 14, 2006 at 10:37 AM
PALMIROS
  • 7 POSTS
[quote:013c6ce305="losone"]Yes, it will work with only the motion detector but you will have problems with unlocking the doors and not cause the motion detector to trigger an alarm. Good luck[/quote:013c6ce305]
So you`re saying that the alarm should work fine, except for locking/unlocking the doors? (i`m talking about the alarm in the link above)
Apr 14, 2006 at 4:52 PM
LOSONE
  • 1,616 POSTS
Yes, you will not be able to use the locking portion but it stills disables your vehicle in case of the alarm. Be careful when you cut your starter wires, make sure you have enough room to add the alarm wires. Good luck
Apr 15, 2006 at 12:31 AM
PALMIROS
  • 7 POSTS
Thank you for your answers. As a final question, I would like to ask your oppinion on the alarm system above (I know its not high end, i`m just looking for something that will do the trick) and how long do you estimate the installation would take?(Considering i can skip some steps, like setting up the lock/unlock, due to the - of powerlocks.)
Apr 15, 2006 at 4:33 PM
LOSONE
  • 1,616 POSTS
all alarms are the same with the names changed to protect the innocent.
The problem is finding the wires to cut and tap. If it was me., I would go to the Zone or Wally World and buy the cheapest one I could find with a motion detector. They all work the same. Good luck
Apr 16, 2006 at 1:51 AM
Suggested Repair
An aftermarket alarm can still be used without power locks by relying on the motion sensor and starter-disable function; remote lock and unlock will not work. Carefully identify and cut the starter wires with enough length to splice in the alarm wiring. A basic alarm with a motion detector is sufficient.
Conversation Summary
The owner of a 1992 Dodge Spirit with no power accessories asked whether an aftermarket alarm would work without power locks. The expert said it can still function through the motion detector and starter disable, but lock and unlock features cannot be used and opening the doors may trigger the motion sensor. The expert advised care when cutting starter wires and said inexpensive alarms with motion detectors work similarly.
