Audio Warnings
GMC
FATHERTYRICIUS
I own a Chevrolet Impala 2001 LS. Two weeks ago I started having a problem where when the key would be in the ignition and doors opened with engine off, the chimes to remind the driver that the key is in the iginition was distorted and going in and out. When I started the car and turned on the radio there was no audio. I turned on the Onstar and didnt get any audio prompts, and when I turned off my Traction Control I didnt get the four chimes that alerts the driver that the traction control is off. Anything audio just goes dead or distorted. I took the car to the Chevy dealer where they replaced the BCM. All worked fine with all audio warnings, radio audio, onstar etc, for two weeks until yesterday when the issue started again where it would distort, and go out completely then come back fine for a while then go back to being distorted. Could the problem be the igintion switch along with the BCM ? After having the original BCM replaced, could it be where two different BCM's experience the same issues? Ive tried to read up on maybe someone else experiencing this same issue with no success. Can anyone here help with some advice and answers ?
Feb 16, 2006 at 9:40 AM
FATHERTYRICIUS
The issue loosing all audio to all features in the 2001 Impala LS has been solved. There is a booster amp mounted in the trunk of all Impala's. The amp in my car shorted and was the cause for loosing all audio to all bells and chimes , radio audio, onstar audio, etc.
Mar 7, 2006 at 11:46 AM
MVANNESSJR
  • 223 POSTS
Thank you for the followup. Glad to hear that you solved the problem and I am sure this won't be the first time we come across this issue!
Mar 7, 2006 at 11:42 PM
Discussion summary
Audio Warnings
The poster owns a 2001 Chevrolet Impala LS and described intermittent distortion and complete loss of all vehicle audio — key-in chime, radio, OnStar prompts and traction-control chimes — occurring with the key in the ignition/doors open and during use. A dealer replaced the BCM and audio returned for about two weeks before the issue recurred intermittently; the poster asked whether the ignition switch or repeat BCM failures could explain it.
Reported outcome: The poster later reported the problem was solved: a trunk-mounted booster amplifier had shorted and was causing the loss and distortion of all audio (chimes, radio, OnStar, etc.).
Read the original discussion
