After Market Stereo Installation
GMC
05GRANDAMGT
My friend has a 95 Grand Am GT, and I'm trying to put in a CD player for her. She didn't buy the wiring harness, so I'm hooking it up to the factory wiring harness. My problem is that the color wires I need, I can't find. I also dont have constant power. It comes in spurts, and the speakers only work when the wires are held a certain way. Any suggestions?
Mar 12, 2006 at 10:52 PM
JPAM
  • 307 POSTS
moved to GM forum
Mar 13, 2006 at 8:20 AM
MVANNESSJR
  • 223 POSTS
Should have bought the harness for $20. Should never cut the factor harness as the wires degrade with age and connections often suffer.
1 Front Left - [Light Gray]
2 Front Left + [Tan]
3 Front Right - [Light Green]
4 Front Right + [Dark Green]
5 Ground [Black]
6 Illumination + [Not Used]
7 Dimmer [Gray]
8 Antenna Trigger [Pink (If Available)]
9 Switched (Ignition) + 12 volts [Yellow*]
10 Constant (Battery) +12 volts [Orange]
11 Rear Right - [Light Blue]
12 Rear Right + [Dark Blue]
13 Rear Left - [Yellow*]
14 Rear Left + [Brown]
*Most common mistakes are using the wrong yellow wire for power.
Mar 13, 2006 at 9:46 AM
