1995 Pontiac Grand Am Radio No Sound
TALON52
I have a 1995 Pontiac Grand Am with radio problems. It receives a signal, and the clock keeps time, but there is no sound coming out of the speakers. I checked the wiring harness, and it is good (no broken wires). Is there any possible quick and easy fix for this? I am not a mechanic by any means, but I do have a little bit of electrical experience. Thanks for your help.
Apr 15, 2006 at 11:38 AM
LOSONE
  • 1,616 POSTS
Sounds like the Amp in the radio is the problem. It is cheaper to get one from the salvage yard or install an after market. You can't fix those radios.
Apr 15, 2006 at 12:21 PM
TALON52
I've posted this same question on a couple of other sites, and they're saying the same thing. Looks like I'm getting a new radio.
Apr 16, 2006 at 8:26 AM
LOSONE
  • 1,616 POSTS
Thats good to check up on us old pros. After 40 years in the business, I have been known to make a few mistakes. Good luck
Apr 16, 2006 at 9:12 AM
Suggested Repair
The radio's internal amplifier is likely failed and cannot be repaired. Replace the radio with a salvage-yard unit or an aftermarket radio.
Conversation Summary
The owner of a 1995 Pontiac Grand Am reported that the radio receives a signal and the clock keeps time, but there is no sound from the speakers. The wiring harness was checked and had no broken wires. The expert said the radio amplifier is the problem, those radios cannot be fixed, and the cheaper options are a salvage-yard radio or an aftermarket unit. The owner agreed to get a new radio.
