1989 Pontiac Grand Am
VICTORYRP
  • 1989 PONTIAC GRAND AM
This is my daughters car. She came home from school yesterday saying she had problems starting it at times. The lights, radio, wipers are working. When you turn the ignition, it is barely cranking (sounds like no juice). I hear a little clicking also. Thanks for any input.
Friday, February 9th, 2007 AT 10:02 AM
MMPRINCE3000
  • 133 POSTS
Check the battery voltage with a multimeter, should be 11.5-12.5 volts.
If battery checks out clean positive and negative battery posts and positive connection to starter (disconnect negative connection first!) And negative connections to engine and chassis and connection to starter solenoid.
If it still clicks, you may need a new (rebuilt sstarter).
Wednesday, February 14th, 2007 AT 11:38 AM
