Alternator, Battery, wiring?
GMC
HEARTS88
Hi, I've got a 1987 Olds Cutlass Supreme with the 3.8L engine.
Recently having problems with what I thought was the Alternator. Car was draining the battery while driving.
Had the Alt tested and it was GOOD!
So I had the Battery load tested and it came back good.
Here is what I personally have found.
Tester on the batter with the car running. 11.5 volts.
Tester on the Battery Ground and the positive on the Alt. 11.5volts
Tester with the Ground on the ALT and Positive on the ALT 15volts
Tester with the Ground on the Alt and Positive on the battery 15volts
I did this with the headlights running and the car at idle speed, I believe about 650 or 750RPM's.
Anyone tell me what is going on. Why do I keep draining the battery.
Is my Ground from the battery to the Engine bad? Should I replace the ground battery cable?
Or the positive cable? Or both?
Anyone that can help...please do... I have no freedom as I can only get to work and to home, and have to charge the battery everyother day or I am not going anywhere.
Thanks
Hearts88
Jan 12, 2006 at 10:20 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the voltage readings repeated with verified meter contacts and loaded voltage-drop tests on the charging circuit, especially the ground path, before replacing cables or the alternator.
Guidance references and applicability
Source: Original question and visible replies. Owner outcomes are attributed; other participants' experiences are not treated as this owner's repair. Next steps are editorial guidance, not a confirmed diagnosis. Fluke: Voltage-drop diagnosis. General electrical testing; no vehicle-specific diagnosis. https://www.fluke.com/en/learn/blog/automotive/electrical-automotive-troubleshooting
Read the replies · Discussion summary and reported outcome
PULSTI
  • 28 POSTS
test the wire between the alt and the batt. my truck would noe charge after a new batt and alt until i got that wire replaced.good luck
Feb 23, 2006 at 6:21 AM
Discussion summary
A 1987 Cutlass Supreme 3.8 repeatedly discharged its battery while driving despite reported good battery and alternator tests. Running-voltage readings changed substantially depending on whether the meter used the battery negative terminal or alternator housing as its reference.
Reported outcome: No repair or follow-up test result was reported.
The ground-reference discrepancy is a diagnostic lead, not proof of a failed cable. The discussion did not document test accuracy or the final fault.
Read the original discussion
