hot alternator
GMC
DANK
i have a 78 Itasca moterhome with a 454 in it it has 80k miles on it, it ran fine when i parked it, well yester day i put a 40amp charger on it and left it overnight(woops).
when i start it my alternator gets to hot to touch in about 5 seconds!!!and it starts to eat up my belt, (i am sure that it is spinning frealy)
but if i take eather the plug or the big red wire off of the alternator it does not get hot and doesnt eat up my belt.
i have replaced the alternator and it still does the same thing, i got my volt meater out and did some testing.( but i realy didnt know what i was doing)
if anyone knows what is going on PLEASE HELP!
thanks Dank
Feb 22, 2006 at 1:16 PM
FISHERMAN
  • 937 POSTS
your alternator has a regulator integrated?
Feb 22, 2006 at 1:24 PM
DANK
im not sure, i think the guy at the parts store said it does, ill find out for sure if you tell me how (lol)
thanks
Dank
Feb 23, 2006 at 6:15 PM
DAVID1984
  • 7 POSTS
You may want to check your batteries. Have them load tested individually, with the posts dissconnected. Most part stores will do it for free.
Feb 23, 2006 at 8:49 PM
DANK
i had it load tested, and it is a good batt., i also found out that my voltage regulator is builtin to the alternator, so that has allready been replaced!
Thanks Dank
Feb 26, 2006 at 2:19 PM
