1992 Chevy Caprice White Smoke Hesitation
GMC
HGREEN
1992 Chevy Caprice. 5.7 Liter, 8 Cyl. 149000 Mi. The car is hesitating when I'm trying to accelerate, (from a complete halt & while driving). Instead of quickly accelerating, it's kind of gradually climbing to my desired speed... And it's usually accompanied by a big puff of white smoke every so often. Any ideas on what to check for first?
Apr 25, 2006 at 12:57 AM
LOSONE
  • 1,616 POSTS
White smoke is never a good sign. You have coolant in your combustion chambers. It runs bad because the plugs won't fire in water.
Remove the plugs one at a time and turn the engine over. the one with water will spray it out. Stay out of water shot.
Disable the ignition while cranking it over. Good luck
Apr 25, 2006 at 4:38 AM
Suggested Repair
Disable the ignition, remove the spark plugs one at a time, and crank the engine to identify which cylinder sprays coolant. Stay clear of the spray. White smoke and hesitation indicate coolant entering a combustion chamber so the plug cannot fire properly.
Conversation Summary
The owner of a 1992 Chevy Caprice 5.7 reports hesitation during acceleration from a stop and while driving, often with a puff of white smoke. The expert says white smoke means coolant is entering the combustion chambers and preventing the plugs from firing. The suggested check is to disable the ignition, remove the plugs one at a time, and crank the engine to find the cylinder that sprays coolant.
