1999 Oldsmobile Intrigue AC Won't Turn On
GMC
RLMURRAY
I own a 1999 olds intrique with 57000 miles on it. I just had my air conditioner( compressor, condenser ect ) fixed last year. It worked last year fine. Now when I hit the air compressor auto button on the dash the green light flashes and then goes out and it doesn't kick on the AC. Also the outside temperature is displaying 20 degree Fahrenheit when it is 80 degrees outside. I am thinking that the AC won't kick on because it is thinking that it is to cold outside because of the incorrect outdoor temperature display. Any ideas on how to correct the situation.
May 4, 2006 at 6:40 AM
LOSONE
  • 1,616 POSTS
Huuum. FIrst disconnect the battery and let the system reset.
You may have a bad temperature sensor. It also may be low on refrigerant.
May 4, 2006 at 8:06 AM
Suggested Repair
Disconnect the battery and allow the climate system to reset. If the problem remains, check the outdoor temperature sensor and the refrigerant level.
Conversation Summary
The owner of a 1999 Oldsmobile Intrigue says the AC will not engage: the dash light flashes and goes out, and the outside temperature reads 20 degrees when it is about 80. The owner suspects the false reading is preventing the AC from running. The expert suggests disconnecting the battery to reset the system and checking for a bad temperature sensor or low refrigerant.
