1989 GMC Pickup Rough Under Throttle
1935 GMC
DERFMIER
I have a 1989 gmc pickup with a 350 and tbi carb. the motor runs good at an idle but runs rough when the throttle is pressed. coudl you please help me?
Mar 11, 2007 at 4:22 PM
MICKEY-D
  • 304 POSTS
You could have a number of different things causing this problem. Bad plug wires, bad plugs, bad rotor, cracked cap, timing off. Those are just a few things you need to check.
Jan 7, 2010 at 3:22 PM
Suggested Repair
Check spark plug wires, spark plugs, distributor rotor, distributor cap for cracks, and ignition timing.
Conversation Summary
The owner of a 1989 GMC pickup with a 350 and TBI says the engine idles well but runs rough when the throttle is pressed. The expert says several ignition issues could cause this and recommends checking the plug wires, plugs, rotor, distributor cap, and timing.
