1990 GMC Top Kick AC Quits While Driving
1990 GMC
EGO RACING
We have a 1990 GMC Top Kick with a 5 speed and 2 speed rear. The Question I have is with the AC system so I am hoping you can help.
Right now the AC is not operational, when you Start the truck and try to turn it on the AC indicator on the control flashes and the fan comes on.
If I disconnect the battery for about a minute and re connect, start the truck and turn the AC on it blows very cold air and will run for several hours without a problem. BUT when you try to drive the truck it will stop within a minute of leaving the driveway, the AC compressor stops operating and the AC indicator on the control starts flashing. The only way to get it working is to disconnect the batteries again.
Jun 10, 2007 at 3:36 PM
E40WATER12
  • 522 POSTS
Sounds like youre A/C button switch is not good, Needs replacing, Or the A/C relay unit wornout.
Jun 11, 2007 at 10:33 PM
MICKEY-D
  • 304 POSTS
I think you have an APADS system. You need to locate the controller and see what light is flashing. You are probably low on refrigerant if it will sit there and cool, but quit at higher RPMs. You could also have a bad low refrigerant switch.
Jan 7, 2010 at 2:57 PM
Suggested Repair
Locate the APADS controller and note which light is flashing. Check refrigerant level and the low-refrigerant switch, since cooling at idle that stops at higher RPM can indicate low charge. Also inspect and, if needed, replace the A/C control switch and A/C relay.
Conversation Summary
A 1990 GMC Top Kick with a 5-speed and 2-speed rear has an A/C system that flashes the control indicator and runs the fan but does not cool. After a brief battery disconnect it blows cold air for hours while sitting, but the compressor stops and the indicator flashes within a minute of driving; another battery disconnect is required to restore it. One reply suggests a bad A/C button switch or worn A/C relay. Another identifies an APADS system and recommends reading the controller's flashing light, checking for low refrigerant, and testing the low-refrigerant switch.
