1998 Chevy Malibu Outside Air Only
GMC
DJSCHWENKE
I have a problem with the heater control on my 1998 Chevy Malibu, 110K miles.
The air source always defaults to "outside" air no matter what blower position I choose (lower or defrost).
Might a switch be bad? Where is it located?
May 12, 2006 at 2:09 PM
LOSONE
  • 1,616 POSTS
Look under the hood for the round black vacuum tank about the isze of a softball.. Check the vacuum lines going in and out. Quite often the small plastic lines break and cause your problem
May 13, 2006 at 6:55 AM
Suggested Repair
Inspect the round black vacuum tank under the hood and the small plastic vacuum lines going in and out of it. Broken lines commonly cause the system to stay on outside air.
Conversation Summary
The owner of a 1998 Chevy Malibu says the heater always defaults to outside air regardless of blower or mode selection and asks whether a switch is bad and where it is located. The expert advises checking the softball-sized black vacuum tank under the hood and its vacuum lines, which often break and cause this problem.
