Check your security guard system if it has it probably think! That you're the burglar and shutdown the system.[/Quote:b91e79bedd]
I don't have a security system. I checked the fuses and they are good. But thanks for the information so far.[/Quote:b91e79bedd]
Read the battery voltage what is it? Double check all connections on the battery. Why did you replace the battery is it because of the present problem or what-talk to me.[/Quote:b91e79bedd]
I replaced the battery because it would not start or take a jump start, when I put in the new battery the truck started and died I started it again and it died, then I checked the fluid levels they were all good, so I started the truck again and gave it some gas to keep it running then I drove it for 1 mile parked it dissconnected the battery the nexted day reconnected the battery and no power to anything it's like there is no battery at all. The battery reads 12V.
Sunday, September 16th, 2007 AT 3:18 AM
