1991 GMC Jimmy Voltage Fluctuation
MIKEYDEP
  • 29 POSTS
91 jimmy sle, 4.3l, 136k.
while driving the other day, with headlights on, i
noticed the voltmeter on the dash slightly fluctuating
when i turned the blinker on...
any clues?
also, sometimes it's hard to start...especially when warm, i have to turn the key a couple times before it
kicks in...
thanks for any help...
Oct 9, 2007 at 10:03 PM
  • 75,988 POSTS
Get the alternator and battery tested. And also the fuel system pressure.
kicks in...
What's happening is when you turn key on and off you're building up pressure, again check the pressure.
Oct 9, 2007 at 10:30 PM
MIKEYDEP
  • 29 POSTS
new battery and no more probs!!
Jan 8, 2008 at 10:53 PM
Suggested Repair
Test and replace the battery if needed. Also have the alternator and fuel-system pressure checked if the voltage fluctuation or hard warm starts continue.
Conversation Summary
A 1991 GMC Jimmy owner reported slight voltmeter fluctuation when using the turn signal with the headlights on, plus occasional hard starting, especially when warm. The expert advised testing the alternator, battery, and fuel pressure, noting that cycling the key can build pressure. The owner later reported that a new battery resolved the problems.
