1995 GMC Jimmy sometimes slow to start
PEPHOUSE
  • 1995 GMC JIMMY
I have owned a 1995 gmc jimmy 2dr 4wd with the 4.3 motor and 96000 miles on it for a year. Since I have owned it there are times when you have to crank the engine for 6 or 7 seconds before it fires. Then there is a puff of black or grey smoke and it runs rough for a second and then runs fine. There are times when the starts are normal. If you stop at a store and restart after a few minutes it is fine. Colder mornings are better. I realize these vehicles are prone to fuel delivery issues but I would like to narrow down my search. Aside from this the vehicle runs perfectly. I have changed the fuel filter checked the spark plugs and installed new ground and positive cables to a new battery.
Sunday, August 12th, 2007 AT 6:44 PM
Check the fuel pressure.
Its losing its hold/residual pressure could be a leak in the fuel line, fuel pump check valve, fuel pressure regulator or 1 or more fuel injectors leaking. Low residual fuel pressure can cause your problem.
Monday, August 13th, 2007 AT 5:41 AM
