1991 GMC Jimmy Hard Starting
MIKEYDEP
  • 29 POSTS
how can i test the alternator?
my jimmy has been not wanting to start without a jump...i'm thinking the alternator may be dying and not charging the system.
reset the brake light switch at the pedal when it got stuck on and drained the battery overnight.
how do i check for a short somewhere, if it's not the alt.?
something is draining the batt......or it's just an old batt?
please any help is greatly appreciated....
Oct 20, 2007 at 2:25 AM
BLACKOP555
  • 10,386 POSTS
id say old batteyr cells are probably not holding the charge. replace and you should be good to go. to test the alternator you can take it off and take it to a auto parts store.
Oct 20, 2007 at 2:33 AM
Suggested Repair
Replace the battery if it no longer holds a charge. The alternator can be removed and tested at an auto parts store.
Conversation Summary
The owner of a 1991 GMC Jimmy reports hard starting that requires a jump and suspects a failing alternator, a parasitic drain, or an old battery. A stuck brake light switch had previously drained the battery overnight. The expert says the battery cells are likely not holding a charge and recommends replacement, with the alternator tested at an auto parts store.
