2002 GMC Jimmy Not starting
198,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIMDEWY69
I have a problem with the truck as it was working fine i went in the house for 1-1/2 hours then went out and tried to start it to go out. It coughed and sputtered then would only go through the motions of starting but would not start. Fuel is not getting to th intake manifold. what could it be? (a clog, fue sending unit, when we put fuel in the intake it wants to start but then burns up whatis there then stops again. Fuel pump is fine.
Jan 9, 2009 at 12:54 PM
BILLYMAC
  • 2,204 POSTS
fuel pump is fin as in you have 60 psi of pressure. the fuel system on this truck the pump wil run and pump fuel but has to have 60 psi because it runs on popit valves under the plantum and wil not open them with less then 60 psi. if you do have the right fuel pressure.then the fuel injection controller is under the plantum kind of expensive but you have to know it is a fuel prob for sure good luck billymac
Jan 12, 2009 at 1:28 AM
