2000 GMC Jimmy Ignition Won't Turn Off
BANEPEAK
I have a 2000 gmc jimmy sle vortec 6cylinder with 123000miles recently when i park and turn the ignition off it will not go to the off position leaving my electricals on inside the vehicle any ideas what is causing this
Jan 20, 2007 at 9:40 AM
  • 55,748 POSTS
yes, your ignition key tumbler or ignition switch has fallen apart inside, disassemble to replace as needed.
Jan 20, 2007 at 12:55 PM
Suggested Repair
Disassemble the ignition assembly and replace the failed ignition key tumbler or ignition switch as needed.
Conversation Summary
The owner of a 2000 GMC Jimmy with a Vortec six-cylinder says the ignition will not return to the off position after parking, leaving the interior electrical systems on. The expert says the ignition key tumbler or ignition switch has come apart internally and should be disassembled and replaced as needed.
